0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#114286 08/08/2002 7:03 PM
I've worked with the two stage paints before but allways one color. This time I am doing two colors with graphics. How much time do I have to put on the clear after both base colors are applied and the graphics are completed. will i need to scuff up the base before the clear is applied. I'm guessing it will take at least a whole day to lay out the graphics and applie the base.
#114287 08/09/2002 12:45 AM
normally you have 12-16 hours to apply the clear coat before having to scuff
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#114288 08/09/2002 2:41 AM
You need to get the tech sheets or view them on the web for the products you are using. There is quite a wide variety in "recoat windows". Dupont has a 24 hour while Sherwin Williams has 7 days and Spies Hecker has forever. What paint are you using?
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#114289 08/09/2002 9:15 PM
using House of Color products. The graphics will be time consuming. only the two colors will be used but the graphic will be time consuming.
#114290 08/10/2002 2:44 AM
I don't have the HOK tech sheets and have not used it in YEARS, but I do know that they have a "Mid coat" clear (basicly a colorless base coat) that is designed to spray over art work to "prolong" the window on the base and to "seal" the art work. I HIGHLY recommend looking into it. It is called "intercoat clear" and the part number is SG100.
Check it out http://www.houseofkolor.com/hok/productset.html
Click on "Kosmic Kolor urethane and polyurethane enamels" to see the "Intercoat clear" and it's discription. Have fun!
1948 Chevy Pickup
