3 members (DadsFirstPickup, 2 invisible),
138
Mod | | | Forums66 Topics128,100 Posts1,056,169 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I have running boards the have some small holes in them where they bolt to the braces.Is there a vender that has patch panels for them ? Maybe I could find a running board that I could cut a patch out of? I would like to use them if all possible .They are factory corrugated,and I have no bead roller dies,or a brake press die to make a panel to match.I could form up some smooth running boards,but would rather make these work. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Jim Carter used to, and my still, sell patches for the running boards. I used them a few yrs, probably 7yrs now!) The tread pattern matches about 95% close. Let us know if they are still available? My trucks is a 1950 AD, which year is yours?
Mike
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I forgot to say that my truck is a 1946 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I had occasion to chop and channel a set of TF/BC era steps. I found cutting along the edge of a corrugation valley or ridge rather than the middle of a valley or plateau made things much easier. It's easier than patching in a large flat panel, that's for sure. So I guess I'm saying find another trashed running board with enough good metal to work with and don't concern yourself with 'If it's Right' from the supplier.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Are the small enough to back them up with a copper spoon and weld fill? Don't make the mistake I made. I cut out about 18" x6" and then couldn't find a patch piece. I even placed a wanted ad here with no luck. I have a bead roller but could get the spacing or dies to match. I have since bought fiberglas replacements. I still have both steel boards that I will play with when time allows. Good luck and have fun Dan | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I was looking around for running board parts for my 41 and could only find the braces that go on the bottom, that attach to the angle bracket.
I was lucky enough to find a pair of good 3/4 ton running boards. So, I still have the ones that need work. It would take someone a lot better than me to make them work...ends are cut off, etc.
BUT, they would be good for parts/pieces. If you let me know what you need, size, etc. maybe I can cut it off and get it wo you.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | |
