2 members (Hotrod Lincoln, Rusty Shackleford), 351 guests, and 3 robots.
Topics128,168
Posts1,057,100
Members48,463
Just agreed to buy a 1964 C20. Wanting to upgrade by adding aftermarket heater and AC, also wanting a modern stereo, under bed fuel tank. Truck appears to have a generator(completely stock).Is it 6volt in 64? To convert to 12, what all will need to be changed? Would like to keep original gage configuration but what happens there when I go to 12v?
Welcome to the Stovebolt wave
Your 1964 truck is 100% 12v since new. The last 6v Chevrolet truck was the 1955 1st series.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Riding in the Passing Lane
As B says, it is already 12 volts. You will need to switch to an alternator if you plan on adding acsesories.
1972 Chevy c10 Cheyenne Super
TY both, alternator now on purchase list
A 64 Chevy truck should have an alternator in it from new, shouldn't it?
Pete
Pete
I believe you are right. He said generator. He will probably want upgrade it to 65 amps or more if he is going to run A/C.
