0 members (), 110 guests, and 4 robots.
Topics128,183
Posts1,057,264
Members48,467
I'm back working on my truck after a few months away, and am trying to remove the propeller shaft and pinion gear. There's a break somewhere, I suspect the propeller shaft, and am trying to disassemble the rear end to fix the problem.
I have the differential out, and the way the shop manual reads, the pinion shaft should just slide out. I can pull it out about a quarter inch, but then it hangs up ( pinion shaft ). I removed the three bearing retaining screws. (item 7 in the shop manual illustration) . Should I use a puller and a little more muscle? Just want to ask before I risk breaking something else.
Also, when I pull on the propeller shaft from the front, it comes out about a half inch and then hangs up. I think the damaged end of the shaft (if it's the shaft that's broken) is hanging up on the bushing. I can try to force it, but again want to ask you guys first.
Thanks in advance for any advice.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
You will need to give the propeller shaft a good smack at the front to drive it back. The rear pinion bearing is very tight in the housing which keeps it from coming out easily.
My Blog
Thanks Dave. I drove the pinion gear out as you said. The propeller shaft was broken near the forward end . I still have to get the front piece of the drive shaft out of the torque tube, since it's hung up on the bushing, but I can drive that out and will then have to shop for parts.
1938 Chevy 1/2-ton
