1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1142031 12/31/2015 2:15 AM
1 Offline
Can anyone confirm the correct location for the sending unit to be installed in engine? Is it the driver side rear most head bolt on top? 1950 216 engine
Yep, here's one with a plug in it:
http://www.pbase.com/dennygraham/image/162201936
dg
Denny G
Sandwich, IL
Crusing in the Passing Lane
So no one is confused, the sending units are normally pipe thread.
Ed
Straight thread on the 1950 216 mechanical sender
1956 was the first year for pipe thread, for the new electric sending unit design.
My Blog
Right Dave and the thread in the 216 head is 5/8-18 not a pipe
thread. Big discussion on that just last week, and those
pictures I linked to illustrate that.
Even though the pitch of a nominal 3/8 NPT is 18 threads per
inch, it is a tapered thread and the 216 sender socket
is UNF which is a straight thread. The tap drill for both
the 3/8 NPT and the 5/8-18 are both 37/64" this is where the
confusion often comes into play.
dg
Denny G
Sandwich, IL
As a philosopher (not you) once asked, Denny: "why would GM ever do that?"
Ran into this issue when I was trying to install an aftermarket electric sender that was 1/8 pipe.
Had to make my own adapter
Ran a 5/8 18 UNF die over a 3/8 brass adapter.
I will never forget that size, got the info from pre68dave
The later heads pipe size is alot larger than 3/8 pipe
1965t5 #1142176 12/31/2015 10:39 PM
Does that 5/8-18 hole in the 216 head have a smaller diameter tapered portion at the bottom that mates up with stock temperature gauge bulb/nut?
Carl
1965t5 #1142185 12/31/2015 11:23 PM
Yes the taper is the seal face for the unit.
1965t5 #1142191 01/01/2016 12:20 AM
Sorry for the misinformation.
Ed
1965t5 #1142280 01/01/2016 12:18 PM
Tks Dusty, and that Tim, is the reason "why would GM ever do that?"
The sender bulb being fixed to a capillary tube meant that it
couldn't be turned so they used the same principal as a flared
tube and flare nut, with a straight thread to seal the bulb
into the seat. And GM wasn't the only one using that was to
install mechanical temp gauges, it was quite common before
the advent of electrical gauges.
dg
Denny G
Sandwich, IL
