| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 12 New Guy | | New Guy Joined: Dec 2015 Posts: 12 | Hey all
Just wondering what the best material is to make door panels or is it easier to buy reproduction ones and change them to how you want them?
beep beep beep truck update
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The reproduction panels are as Brad posted, simply paper board aka; cardboard. This was the same material that was used in the headliner. The original side panels were made from upholstery grade water proof panel board, which was embossed with a leather grain pattern and painted. Panel board usually comes around 1/8” inch thickness (.100”) and would fit in the trim ring of an AD truck side panel. Treated waterproof panel board is still used in automotive applications and is available from upholstery suppliers such as this: http://www.perfectfit.com/15347/154...Black-Treated-Waterproof-Panelboard.html Simulated leather grain book covering can be found at book binding supply companies. This is some with a heavy leather grain that I’ve used to restore hard cover radio schematic books (Riders & Sams): http://www.pbase.com/dennygraham/image/162229367This is Navy Blue but is made in many colors and patterns. This particular material is .015” thick and could be applied to a panel board with glue using a roller or a vacuum bag. The total nominal thickness would still be under 1/8” and should fit in the U-channel trim rings on our AD’s. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used the inexpensive cardboard panels the vendors sell. Treated it with waterproofing and glued fabric to it from the fabric store (joanns fabrics) ...pic... Its held up since 2010, but I dont get much rain where I live. Probably only driven in the rain a dozen times. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That fabric looks real good Gus. Judging from the grain pattern, it appears to be Naugahyde fabric? How in the world did you get the "sandwich" to fit inside the trim ring? It was all I could do to get the reproduction panels into the reproduction trim rings. Any more thickness and I would have had to spread them apart. We're probably giving the readers a bad impression of the reproduction cardboard panels. I installed the ones I got from the vendors back in 2006 and they still look as good as when I put them in. Like you, she doesn't get driven in the rain unless I get stuck in it when I'm out. http://www.pbase.com/dennygraham/image/162231265dg
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Gus,
I'm interested in your answer too. I'm considering going a similar route, and the "sandwich" thickness is a concern I haven't gotten resolved yet.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I had no issues with thickness of the material I picked up from joanns fabrics ...pic... ...pic... ...pic... | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thanks, Gus. I'll go ahead and give mine a try before I plan anything unusual. As always, thanks for your quick, thorough responses, with excellent visuals  Bill
Never, never, never, never give up. - Churchill | | | | | Joined: Jun 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 25 | Thanks for all the photos. You guys do some good work. I agree that before I saw photos of the "cardboard" I was thinking geez, it's cardboard. But the appearance looks like it has a thin layer of vinyl over it.
That is probably the route I will go. I have a 1949 3600, maybe it came from the factory with vinyl covered cardboard? | | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | DADS50, Do you have a stock number on the material you bought from Joann's Fabrics? Also, what did you waterproof the cardboard with? I used the inexpensive cardboard panels the vendors sell. Treated it with waterproofing and glued fabric to it from the fabric store (joanns fabrics) ...pic... Its held up since 2010, but I dont get much rain where I live. Probably only driven in the rain a dozen times. Thanks, | | |
