| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 24 | Happy New Year! I am the guy that just bought a 52 Chevy Pickup equipped with a 235 with a bad miss. I posted that I wanted to possibly replace the 235 with a 283 or 409 that I currently have but wanted to correct the miss and drive the truck for a year or so before making my decision. Well today I began with a compression test as a starter in order to tackle the miss. Ok, wires are off and the plugs are out and here goes, plug #1, 115 to 118. Plug #2 115 to 118. Plugs 3, 4, and 5 record 115 to 118 as well. Ok now time to crank the engine and check #6 plug, and you may have guessed it, nobody home, a solid Zero! Now what as I lean back on the bench? Then I remembered what I was told to do that I learned on this forum from you guys. I removed the valve cover looking for a stuck valve or bent push rod. There it was, #6 push rod was un-seated! I uncranked the top bolt, seated the push rod, and cranked the bolt down to it's original position. I the took a compression test and it came up a 100. Originally the plugs were fouled but #6 was wet with fuel. I replaced the valve cover and the miss was gone. The truck still runs a bit poorly but that is from the leaking and poorly set carb. I removed the single barrel Rochester and it is going to be overhauled. I also have all the parts for a total tune-up. I must take this moment to thank all of you who responded to my original post and for saving me a ton of money and time! Again, Happy New Year and a huge thank you! Rich
Retired Military, Six years Army, Seventeen years Air Force Army Security Agency High Speed Morse Code Intercepter Rigger C-130 Master Sergeant 32nd Aerial Port Squadron Commander American Legion | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Hope you set the valve clearance so you won't burn a valve. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I recommend you find a Carter YF Carb, far better than the rochester and a one for one switch.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to post the year of your 235 and/or the Engine Serial Number (pressed into the block to rear of the distributor.
The carburetor fittings (bolt distances on the intake manifold, in particular) differ over the years. | | |
