| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Hey all,
On my '55 2nd series 3100, (It is the fancy cab with all the chrome trim and knobs.) I have two holes in cab by windshield for sun visors. Not sure if the are original or if at some point someone just put a set of visors in. Did these truck originally come with a set of visors, or just a drivers side visor, or did someone just cut and drill holes? Thanks for the help. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | just a driver side visor was standard, but a pass side visor was available as an accessory, or it may have been part of the "Custom Cab" option if that's what yours had Bill | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The factory put in both holes. The right hand cabs needed a sun visor too. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Jim, The 55-59 Right Sun Visor holes could be factory, dealer or owner drilled. Cabs shipped from the factory without the right visor were not pre-drilled. Mike B  | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | interesting, must have stopped in '54. 47-53 had both because of right hand drive models and/or optional orders | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Did the AD's trucks have some sort of a cover if the visor wasn't installed? The TF visor requires a large hole (about 1-1/2") in the middle of 3 screw holes...wouldn't look good if the visor wasn't installed. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think (I bet) there were holes in the cab sheet-metal for the add-on passenger-side visor in all A-D trucks. Those holes are in my 1954 cabs.
Only the driver's visor ("sun shade") was standard in 47 to 49/50 cabs/trucks. The passenger side sunshade was an accessory in all cabs/trucks in these years.
From 51-55st, the passenger side sun shade was standard on Suburbans - it was an accessory on all other models.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Did the AD's trucks have some sort of a cover if the visor wasn't installed? The TF visor requires a large hole (about 1-1/2") in the middle of 3 screw holes...wouldn't look good if the visor wasn't installed. Mike B  The holes were hidden by the ceiling liner. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | "The holes were hidden by the ceiling liner. " That explaines it, thanks! The TF trucks did get 4 little dimples in the sheet metal to know where to drill the holes. Mike B  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Think anyone could snap a picture of that corner of a TF truck. That might clear the water for anyone asking about this again, thus avoiding pages of questions and supposition.
The hardest part adding a visor to an AD's cab, is guessing at just exactly where the factory put the holes behind the head liner. dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Denny went out to take a picture of mine. Pass side was all smooth. The dimples must of all been filled in over the last 60 years at some time.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for posting those Tim. Mike sent me those but I had no idea how to post a pdf to my album. It's those little details that keep me interested even though it's not an AD.
dg
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Thanks Tim (and Denny for trying)!!! Happy New Year! Mike B  | | |
