11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | Hello,
I am looking for a part number for the master cylinder on my GMC 630-50. The maintenance manual I have for the truck only lists MC bore of 1 1/2". The original out of the truck is too rusty to read any numbers on it. Any help would be appreciated.
Thanks in advance.
Alex
Alex
1954 GMC 630 Pumper 1963 Ford F350 Various antique farm tractors
| | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | Some photos: MC 1 MC 2 MC 3
Alex
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hope you get an answer, cuase I need the same for my 54 630. Ron | | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hey Alex. What engine do you have in yours? | | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | cff, It has the GMC 503 six cylinder, what do you have?. Also has a hydrovac in case that helps anyone.
Alex
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | MC's for this era truck are very hard to find new, however they can be sleeved and rebuilt with a NAPA kit in most cases. Mike B  | | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | Are the NAPA kits standard based on bore size?
Alex
| | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | I got the MC disassembled tonight. I did not find any pitting. What are everyone's thoughts on honing the cylinder?
Alex
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If the bore is clean all the way out then I might make a quick pass with the hone just to make sure there are no low spots and to clean up the bore area that is outside of the pistons normal travel area. Then buy a new kit and put it back together... Mike B  | | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Alex. Mine is the 503 also. Pretty cool engine. Mine is an old fire truck. Ron | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I also have a '54, someone replaced the bed and pump w/ a flatbed and U-joint hangar, 503 w/ 5 speed synchro, need PTO for box, drove home to Denver area from Al, brakes take 4 pumps to work may need hydrovac? Repair. 503 works fine, 6 to 9 MPG on way home, 6.5 rear ratio, needs 4.8 or so.
Made up electronic ignition so far, not installed yet, Deve's mod. Thinking about fuel injection in the future, want to keep gasser.
Ed
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hi Alex. Sorry about taking so long to get back to you. Just started back to work today and hadn't been checking the computer at home. Busier at home than I am at work LOL.I live in BC Canada and I bought the truck in Idaho. I got it back to Lynden Washington and I had leave it there till I got my paperwork in order.Hope to have it back here on the 10th of Dec.I have a few pics,on my phone, but I don't know how to post them here. If you give me your email I do know how to email them from my phone. Don't know if the tranny is syncro or not. It is a 5-spd.Needs a master cylinder, so I trailered it from Idaho.Mine is a General also. | | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hi Ed. Hey that's a lot better mileage than I thought it would get.That's 7.5-11.25 on a Canadian gallon. Any Pics? | | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Love the pics of yours Alex. And Ed, what is the Deve's Mod electronic ignition. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | The Wagner part number for the master cylinder is 3374 1-1/2" bore the kit number is 11310 hope this helps.
Marv. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Marv,
Thanks for the MC info.
I don't know to post px either, send me your email via pm and I'll send some.
When someone replaced the pump with a carrier bearing and new driveshaft(s). (Good) They must of have lost the 16" Tru-stop brake disc, so, some true genius replaced it with a 14" one which wore a 14" groove in one of the shoes, hard to release, also. Luckily, in my junk, I have a 16" disc so when it warms a little(14F this AM) I'll swap and reline the shoes.
Ed
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hi Ed. My email is [email protected], Ron | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Marv. I have tried to find that wagner part number for the master cylinder, but no luck. I have a counter guy at O'reillys trying to find something, but no luck yet with him either. Where did you get that part number? Ron.
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Ed. I didn't get your email with the pics. Are you sure you copied my email address exactly? Ron | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | OK guys, I found some on eBay, FC-11310. I ordered one, for $20. I figured it was worth a chance, they have some more. It looks just like a normal ms rebuild kit, 1.5" dia. In original, sealed box, no rust. Good luck.
Ed
| | | | | Joined: Feb 2015 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 44 | Hi Ed. Did you get yours yet? If so, does it look like it's going to work? I think I'll buy one anyways. It's only $20 and if it doesn't work, I'll display it on a shelf in my shop. Ron | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I got it, measures 1.5" OD, haven"t taken MC out yet. Looks nice, clean, no rust or corrosion.
Ed
| | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | Ed,
Did the ebay rebuild kit work out?
Alex
Alex
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I don't have the mc apart yet, probably be a while.
Ed
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Got the mc out, clean as a whistle. The mc repair kit((FC-11310) I got fits perfectly, no spring though. So, if you have not gotten one for yourself, go ahead. By the way, no auto parts places could find that part number, an IHC truck place found it on EBay.
I do not see anything wrong with mine to cause it to take 4 pumps to get solid brakes, I was hoping it would be a clogged feed port, so after I put it back together and it still does not work, I'll go through the hydrovac.
Ed.
