2 members (Hotrod Lincoln, Millenimech), 76 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1141768 12/29/2015 4:06 AM
have a 52 chevy 1ton. trying to rebuild the fuel pump. ? how do i get this off[IMG]http://i1296.photobucket.com/albums/ag3/cuz2424/IMAG0066_zpskryvz4nb.jpg[/IMG]
jimbo 24 #1141802 12/29/2015 2:33 PM
I believe you need to press it off. I haven't done the one for the truck yet but when I did my 57 Olds it had to be pushed out with an arbour press with an adapter I made to push the head back through the plate. I'll look for some pictures of the set up I used.
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
jimbo 24 #1141805 12/29/2015 2:45 PM
Here is how I pressed the shaft out
http://s1142.photobucket.com/user/52_Ton/library/57%20Olds%2098%20Starfire?sort=3&page=1
Once it was out I had to straighten the washer out and then replace the diaphragm and reassemble.
I bought the kit from Hal at http://www.classicpreservation.com/fuelpumpkits.html
It came with full directions to do the rebuild.
Hope this helped.
Mark
jimbo 24 #1141885 12/30/2015 2:09 AM
thanks mark i will call him tomorrow unless i get it off
