| | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11415 04/15/2002 11:22 PM | Joined: Oct 2001 Posts: 10 Member | | Member Joined: Oct 2001 Posts: 10 | Did GM not have an over head cam straight 6 in the late 60's? It seems to me that I had a friend at the time with one is his car. It seemed pretty hot for a faily small engine. What got me thinking about this is that I have a Jag sedan with a 3.8L (about 232 ci) DOHC straight 6. This car weighs a couple of tons, and flies with this engine. I was wondering about the GM engine in a truck. I have never seen any references to it, and have searched this site without any luck.
Thanks David | | |
#11416 04/16/2002 12:08 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | You are looking for a 1966 pontiac tempest or lemans with the ohc six. Good engine but hard to find. You may have to buy a hole car to get one. Depends how much $$$$$ you want to spend.
if it dosen't need fixed, break it
#11417 04/16/2002 3:08 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Actualyy the engine was available from 1966 to 69. in one barrel version for base engienand four barrell in higher out put. Engine was also available in the Firebird
First engine I ever rebuilt. Learned a lot, had fun. Pretty reliable engine | | |
#11418 04/16/2002 3:57 AM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The Pontiac cammer 6 was made in 230 and 250 cu in sizes. The "sprint" version made 215 HP with a 4 barrel and dual exhausts. Car & Driver magazine put one in a Jag. Purists were not amused.
They can be found in wrecking yards but the cams and cam journals are a weak point and no replacement parts are available. Too bad;it was a good motor. | | |
#11419 04/16/2002 12:45 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Awwwwwwwww now yer bringing back memories: I had a 66 tempest with Lemans option in it. It had a Sprint 6 OHC. It wasn't that great of a motor. Needless to say I blew it up,and changed over to a 389/375 HP. and changed the front coil springs to handle the weight. Also the 6cyl came with a 3 speed manual and I put in a muncy 4 speed. Good luck finding one , not many in the bone yards worth anything.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
#11420 04/16/2002 3:38 PM | Joined: Oct 2001 Posts: 10 Member | | Member Joined: Oct 2001 Posts: 10 | Thanks for the updates. Gee perhaps I should take the DOHC 6 out of the Jag, it is mated to a 4 speed with electric overdrive  The Jag (a 63) weighs in over 4200 lb, and flies with this engine. Triple SU carbs. A staggering 8 miles to the imperial gallon. My wife probably would not approve though. Don't know what the purists would say to an english engine in old American Iron. David | | |
#11421 04/16/2002 5:41 PM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | back in 65 we pulled a ohc jag motor out of a xke and installed a big block chev. the well drillers next door took de jag engine and used it to drive a irrigation pump in tacna az. i thinkzz a ohc jag in a stovebolt would be very intresting and you could use a jag rear end smooooth
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#11422 04/16/2002 8:26 PM | Joined: Sep 2001 Posts: 4 Member | | Member Joined: Sep 2001 Posts: 4 | How about a 77 rice grinder 280z engine? a few inches shorter than my 261. Can produce 200+ hp. I have one in the shop it has been a thought. My brother had a 69 Firebird Sprint with the overhead cam 6, 4 barrel and three speed, great little car. Not enough hp for him so he put 327 vette engine in it. I'd of kept the 6cyl. but i like sixes better any ways. Just my thoughts on this> Big Al
If it don't fit get a bigger hammer
#11423 04/18/2002 2:37 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I also had a bud with a 69 firebird and the 250 ohc, it was a great car, but as usual, he wanted a v-8. whaever, I liked it, my brothers had Xk140s and XK-e's (coupe and roadster) so I knew that the 6's could be made to go.
I think you should put that jag motor in there - after all - people used to stuff chevy v-8s in the jag sedans all the time when they got sick of lucas electrics, waiting for parts, etc.... :p | | |
#11424 04/19/2002 6:55 AM | Joined: Apr 2001 Posts: 23 Member | | Member Joined: Apr 2001 Posts: 23 | Right on Bullfoot! In the days of long ago and far away, we once put a 327 into an Austin Healy 3000 (you could still find one back then, that tell you how long ago it was?). It wouldn't turn very well after that, but it would do second gear wheelies! | | |
#11425 04/19/2002 4:50 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | BMW has taken the straight six and made art out of making it perform. The 2.5L in my 325i really propels that car, and it still gets 26 mpg. It's an overhead cam slant six with a crossflow head and port fuel injection with dual exhaust. I think it is an aluminum block and head, too. I wonder if there is a BMW head with the same bore spacing as a Chevy 6?
