2 members (Wayne67vert, Wally / Montana), 309 guests, and 8 robots.
Topics128,087
Posts1,056,112
Members48,434
#114156 01/11/2004 1:14 PM
Hellow every one. Wondering if any one knows the difference between 47-53 and 54-55 AD inner fenders. I am trial fitting the fenders and grille on my 1954 1/2 ton the front of the left inner fender keeps the grille from pulling up against the fender at the parking light. The angle on the front of the inner fender appears to be different than the angle on the mounting flange on back of the grille,I bought this inner fender a while back supposed to be a 54 wondering if it could be a 47-53 and causing the problem.
DAVE S.
#114157 01/11/2004 2:43 PM
I cannot tell you the difference, all I can tell you is the 54 parts manual says the 54s are different from 53 and earlier years. Or least it gives different part numbers.
#114158 01/14/2004 11:23 AM
Hey guys Hows it going? I had that problem too. Except my inner fenders are 54-55. The only difference between the two are the 54-55 has 3 holes running across the front lower portion of the inner fender's where the grill bolts to it. I have a set of 47 2nd series-53 inners I will look and see if they have those ame holes I don't think so because the grills mount differently but you know chevy- almos everything enterchanges.
Hope this helps.
#114159 01/14/2004 11:24 AM
Hey guys Hows it going? I had that problem too. Except my inner fenders are 54-55. The only difference between the two are the 54-55 has 3 holes running across the front lower portion of the inner fender's where the grill bolts to it. I have a set of 47 2nd series-53 inners I will look and see if they have those same holes I don't think so because the grills mount differently but you know chevy- almos everything interchanges.
Hope this helps.
#114160 01/14/2004 6:46 PM
Brian,Mario thanks for the info. My inner fenders do have the 3 holes for the grille mounting, grille will just not pull up flat against them at those 3 mounting points .
DAVE S.
#114161 01/15/2004 7:22 AM
hey hope it helps you out as much as possible...those ole ad's were built pretty tight and once you take one apart- boy you find that after all the years of twisting and rust and all, the parts don't always go back as easy as when we take them apart. You will have to use a little force to line up those inner fenders to the grill. It will work one bolt at a time.
Good luck. keep on stovebolting!!!!
