| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 5 Member | | Member Joined: Jan 2004 Posts: 5 | Hellow every one. Wondering if any one knows the difference between 47-53 and 54-55 AD inner fenders. I am trial fitting the fenders and grille on my 1954 1/2 ton the front of the left inner fender keeps the grille from pulling up against the fender at the parking light. The angle on the front of the inner fender appears to be different than the angle on the mounting flange on back of the grille,I bought this inner fender a while back supposed to be a 54 wondering if it could be a 47-53 and causing the problem.
DAVE S.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I cannot tell you the difference, all I can tell you is the 54 parts manual says the 54s are different from 53 and earlier years. Or least it gives different part numbers. | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | Hey guys Hows it going? I had that problem too. Except my inner fenders are 54-55. The only difference between the two are the 54-55 has 3 holes running across the front lower portion of the inner fender's where the grill bolts to it. I have a set of 47 2nd series-53 inners I will look and see if they have those ame holes I don't think so because the grills mount differently but you know chevy- almos everything enterchanges. Hope this helps. | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | Hey guys Hows it going? I had that problem too. Except my inner fenders are 54-55. The only difference between the two are the 54-55 has 3 holes running across the front lower portion of the inner fender's where the grill bolts to it. I have a set of 47 2nd series-53 inners I will look and see if they have those same holes I don't think so because the grills mount differently but you know chevy- almos everything interchanges. Hope this helps. | | | | | Joined: Jan 2004 Posts: 5 Member | | Member Joined: Jan 2004 Posts: 5 | Brian,Mario thanks for the info. My inner fenders do have the 3 holes for the grille mounting, grille will just not pull up flat against them at those 3 mounting points .
DAVE S.
| | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | hey hope it helps you out as much as possible...those ole ad's were built pretty tight and once you take one apart- boy you find that after all the years of twisting and rust and all, the parts don't always go back as easy as when we take them apart. You will have to use a little force to line up those inner fenders to the grill. It will work one bolt at a time.
Good luck. keep on stovebolting!!!! | | |
