6 members (Millenimech, Gib70, Hotrod Lincoln, Steelonsteel, Gray_Ghost, 1 invisible), 149 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#11413 10/24/2004 7:27 PM
Hey guys...
I have a master cylinder, power booster and swing pedal assembly from a 1991 Chev van. (fullsize)
I want to retrofit this to my 52 Chev p/u.
I believe the donor vehicle had anti-lock brakes.
Anyone know if the master cylinder for an anti-lock equipped vehicle is different from a non anti-lock master cylinder? If it is different...would it still work for my truck?
The '52 will have front discs and rear drums(same as the van), but will not have anti-lock brakes.
Thanks in advance for any help!
Steve
'49 3800
'52 3600
'57 3100
H Online: Content
Check with a dealer or parts store to see if there's a different part number for an ABS master cylinder. There is usually a return line to the reservoir for all four brakes on the ABS system, for when the solenoid valves vent fluid back to the M/C during ABS operation.
