0 members (),
207
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Built a new stomp starter for the 48 2 ton since the automatic trans did away with the original. A tractor starter button that fits perfectly into the hole in the floor, machined an adapter to mount the original peddle to the switch, shortened the rod to compensate for the height of the switch and there it is. I think it will pass for original with the carpets and padding in place. Wired from the battery pole on the starter to the switch, through the shifter safety switch and back to the solonoid. http://s1276.photobucket.com/user/jsdesign2/library/ | | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 |
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I like that. Was just dreaming about the same solution myself, glad you did the hard part and figured out the details!
Thanks, Grigg | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I can't remember which tractor I bought that switch for, but I'll look it up, sure it's an off the shelf Tractor Supply part.
| | | | | Joined: Aug 2015 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 86 | HI Jim - Looking forward to hearing what the switch was so I can do the same! Thanks for sharing! | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 |
It's a switch for a Case/IH tractor.
| | | | | Joined: Nov 2004 Posts: 2,414 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,414 | Great idea, thanks for the info.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | It may have some other uses, but I have it listed for a Massey Ferguson TO-20 and TO-30. The IH switches generally have a taller button shaft.
I machined the cap to mount the shortened Chevy shaft so it was just about line to line with the push button so it was very snug and then put a #8 set screw in the side. It feels very solid. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The OEM part number is 181679M1 | | |
