3 members (Otto Skorzeny, msmall, 1 invisible), 143 guests, and 1 robot.
Topics128,137
Posts1,056,471
Members48,441
#1139884 12/17/2015 10:06 PM
Built a new stomp starter for the 48 2 ton since the automatic trans did away with the original.
A tractor starter button that fits perfectly into the hole in the floor, machined an adapter to mount the original peddle to the switch, shortened the rod to compensate for the height of the switch and there it is.
I think it will pass for original with the carpets and padding in place.
Wired from the battery pole on the starter to the switch, through the shifter safety switch and back to the solonoid.
http://s1276.photobucket.com/user/jsdesign2/library/
Unconventional Thinker
Looks good to me
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
I like that. Was just dreaming about the same solution myself, glad you did the hard part and figured out the details!
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I can't remember which tractor I bought that switch for, but I'll look it up, sure it's an off the shelf Tractor Supply part.
HI Jim - Looking forward to hearing what the switch was so I can do the same! Thanks for sharing!
1951 Chevy 3100 1/2-Ton
"Piecing it Together - Blow by Blow"
Follow in the DITY
More photos in Flickr
1939 Chevy 3/4-Ton
In the Project Journals Forum
It's a switch for a Case/IH tractor.
Former Workshop Owner
Great idea, thanks for the info.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
It may have some other uses, but I have it listed for a Massey Ferguson TO-20 and TO-30.
The IH switches generally have a taller button shaft.
I machined the cap to mount the shortened Chevy shaft so it was just about line to line with the push button so it was very snug and then put a #8 set screw in the side.
It feels very solid.
The OEM part number is 181679M1
