| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11413 10/24/2004 7:27 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Hey guys... I have a master cylinder, power booster and swing pedal assembly from a 1991 Chev van. (fullsize) I want to retrofit this to my 52 Chev p/u. I believe the donor vehicle had anti-lock brakes. Anyone know if the master cylinder for an anti-lock equipped vehicle is different from a non anti-lock master cylinder? If it is different...would it still work for my truck? The '52 will have front discs and rear drums(same as the van), but will not have anti-lock brakes. Thanks in advance for any help! | | |
#11414 10/24/2004 8:12 PM | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Check with a dealer or parts store to see if there's a different part number for an ABS master cylinder. There is usually a return line to the reservoir for all four brakes on the ABS system, for when the solenoid valves vent fluid back to the M/C during ABS operation. Jerry
