8 members (cmayna, Gray_Ghost, Donf, Otto Skorzeny, Gdads51, Jon G, Forty9, Shade Baby), 104 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
#1141267 12/26/2015 3:21 AM
MFW
Offline
I noticed a suction noise in my truck and found that the rubber vacuum line that connects to the wiper motor hanging down. When I hooked it back up to the wiper motor the trucks idle kicked way down. So, I tried adjusting the idle and it wouldn't adjust. Also the wiper motor doesn't turn on when hooked up. Is there a reason why the trucks idle kicks down and won't adjust? Thanks in advance.
MFW
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
MFW
Offline
Sorry I posted in the wrong section.
1950 GMC 100
1954 GMC 470
More pix on Flickr
There might be two tubes on your wiper motor. You might be attached to the wrong tube?
"Kicking way down" means you blocked a vacuum leak by attaching the hose. The hose was probably leaking for quite a while and you compensated on the mixture and idle adjustments over time.
You now have to reset the throttle plate screw (fully closed and then 1-1/2 turns open), then adjust the idle mixture (same) and tweak until you have the best idle.
MFW
Offline
I will look again under the dash. I did however try to adjust the idle and as I twisted the screw it didn't do anything. Idle stayed the same.
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
