0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | What is the difference between an earlier 47 mirror and a 53 for the driver's side? And does anyone have the later driver or passenger side?
'53 Chevy truck 1/2 ton
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I woulld have to say the arm is at a different angle in the later years to avoid contact with the vent window if it's open and the door is opened all the way.
Joe
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | That is correct, when the vent windows were put in, the mirror arm was bent down to avoid contact. I have a NOS arm, email me if you want to buy it. | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I hope you don't want an arm and leg for it! Nyuck nyuck nyuck | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | wow 2001 this is the oldest post here i so gotta say somthing even if it's nothing. . .
MIKEY DRAGSTER ! ! !
1962 GMC K3000, GMC-379 V6.
