Whenever I have done fender welting,be it a Mack or a F**D,you typically punch holes for the bolts,just keep them an even distance form the edge,cut "V" cutouts on the inner edge so it can bend a tight radius.The Mack factory had it stapled to the headlight panels.So,if you glue it,you are not too wrong,as long as it does not show.
