1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | hey it's me again... my hood is seperated in the front about 1 foot. I think it is the reason my hood doesn't line up horizontaly in the front. How can I pinch it back together. Should I tack weld it? Don't have access to a rivit gun. tell me what you think... | | | | | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | Why dont you get a cheap pop rivet gun and use pop rivets. Or you could use #4 screws and locking nuts. Pop Rivet Gun at home depot is $10.00 | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Marlo, what year & make of truck are ya workin' on ?? | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | mother trucker it's a 54 with a 250 and 2004r tranny with all wheel disc brakes. I replaced the 3 window cab with a 5 window. The hood is just bugging me...got a good for sale? cheap? | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I use a pair od vise grips to hold it together and use small screws with loc washers. I actually took two hood apart to make one good hood. Good luck!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
