2 members (gswbbc, wilbur53), 139 guests, and 3 robots.
Topics128,035
Posts1,055,446
Members48,422
#1140226 12/19/2015 10:35 PM
A little help guys. Installed new upper control arm shafts bushings and seals on my upper control arms(63 C10) torqued to around 160lb/ft. centered the shaft. the rubber seals are still not snug. Correct shaft
Mevotech+MK6098
Thanks gang
[IMG]http://img.photobucket.com/albums/v230/scott657/DSC_0262_zpsxxlck8lc.jpg[/IMG]
I heard that some vendors sell seals that are not correct, so I'm wondering if that is the issue. I'm sorry that I don't know where to tell you to look for the right ones. If my memory serves me, Early Classic Enterprises has the right ones and I read somewhere that LMC control arms seals are not correct. Maybe someone here has bought some and can chime in.
Thanks Lug, I thought I was losing my mind. Im using the provided seal. Based in the way it looked when I dissasembled it the seal didnt do much good anyway.:).
