0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I have new glass installed in the metal window frames (no vent windows)for the '40 cab, but didnt take em out and dont know how they are installed. The window has an open channel along the bottom, and I can see the 2 posts on the regulator, but what keeps those posts from simply falling out of the channel? I have nothing in the window groove around the door(need some felt/rubber?)and also need weather stripping for both doors. This truck is not original and if the orig weatherstripping is high, I could probably use a universal type stripping around my doors. How about maybe a picture of that window on a regulator and some ideas on where I could purchase the channel lining and door rubber. thanks, George in Tallahassee [email protected] | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Steele Rubber Products for your replacement rubber. They have an on line catalog. As for the mechanical stuff I'll let the experts handle that question.
| | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | Jim Carter will have the products you need for your windows and doors.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Thanks, but someone please tell me how the window glass w/frame that has an OPEN track on the bottom stays in the regulator pins? Am I missing something- seem to remember that window channel usually has edges to keep the rollers in them? George | | | | | Joined: Apr 2015 Posts: 3 New Guy | | New Guy Joined: Apr 2015 Posts: 3 | On my 54 Chevy 3100, the door glass has no frame, but moves down felted channels on each side. The glass is pressed into a window track on bottom edge that the regulator roller fits into. On mine, there is nothing on either end of the track to keep the roller in, it just doesn't go close to the ends for that to be a problem. Classic Parts has a good video on the door rubber installation (47-61). | | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | 54 rattletrap..........thanks for that info, wondering if your TRACK is just open on one side- with no lip. I can understand that the rollers cant travel far enough to drop off of the ends, but newer cars I worked on had channels that had short turn downs so that once the roller was inserted at either end, it could NOT fall out. Maybe these do not have that extra length on the open side but the felt keeps the glass rigid enough to stay put. | | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Thanks PAUL in WNC! I stay near Asheville all summer in Spruce Pine......you must be close! I looked CLOSER at my side windows and sure enough, what appeared to me as a completely open track had that slight indention on the top that you pointed out. I can see now how the weight of the glass along with fairly snug felt surrounding would keep the glass in place. THANKS! | | |
