3 members (Gray_Ghost, walter74, 1 invisible), 107 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#114011 05/07/2005 10:57 AM
Junior Member
Junior Member
Has anyone tried the Rust Stop RS2000 product for electronic rust protection? I am bringing a '49 to Hawaii and need to be very vigilant about rust. I'm wondering if this is a worthwhile product.
Aloha,
Rich
#114012 05/07/2005 11:14 AM
It may or may not be worth the cost. I tried to do a little research on the subject and found very little independant study on the web about its effectiveness, other than what the manufacturer claims. It should protect against some galvanic corrosion, as long as the effort is made to electrically ground all body panels and parts together. The problem occurs if the system is improperly installed. If the potential is backwards it can accelerate corrosion instead of preventing it. There is also some argument about whether moist air is actually an electrolyte or not and whether the system even protects if its not submerged in water.
Ontario seems to be using a version of this system to protect bridge decks:
http://www.mto.gov.on.ca/english/transtek/roadtalk/rt10-1/
Paint & Body Shop moderator
