| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 36 Junior Member | | Junior Member Joined: Apr 2005 Posts: 36 | Has anyone tried the Rust Stop RS2000 product for electronic rust protection? I am bringing a '49 to Hawaii and need to be very vigilant about rust. I'm wondering if this is a worthwhile product.
Aloha, Rich | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It may or may not be worth the cost. I tried to do a little research on the subject and found very little independant study on the web about its effectiveness, other than what the manufacturer claims. It should protect against some galvanic corrosion, as long as the effort is made to electrically ground all body panels and parts together. The problem occurs if the system is improperly installed. If the potential is backwards it can accelerate corrosion instead of preventing it. There is also some argument about whether moist air is actually an electrolyte or not and whether the system even protects if its not submerged in water. Ontario seems to be using a version of this system to protect bridge decks: http://www.mto.gov.on.ca/english/transtek/roadtalk/rt10-1/
