| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Today I was under my 46/7 with s10 frame and was wondering what I would do for an exhaust system. The gas tank takes up the drivers side. I really want to run dual exhaust. Are lake pipes an option or are they way to loud, I want it loud but I still want to be able to think while driving. Any and all suggestions welcome. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | You could move the tank to the rear, behind the rear axle. I installed a NASCAR-type fuel cell in a friend's 66 Mustang because he was a little spooked by the stories of rear end wreck fires, and there are several sizes of them that can be adapted to the S-10 frame easily. They're also fairly inexpensive. Jerry
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I have a set of Thrush sidepipes I'm planning on putting on my 41 3/4 ton. I don't think they'll be too loud. May get some "unusual" glances though
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | On my S-10, I cut the Y-pipe, (where the two pipes make one)to make duel exhaust.Ran the pipes down the passenger side. I installed mufflers just in front of the rear axle then piped over the axle and exited pipes either behind each rear wheel or both behind passenger rear wheel. I ran both configurations and also tried regular mufflers and glasspacks. Depending on the configurations all produced their own particular sound! I liked the stock mufflers exited to the same side behind the passenger tire best! (This was using the stock v-6 motor) | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Built several V8 Luvs with tank on left side and did exactly as Frank suggested. First couple had one pipe bent to give traditional dual exhaust under the back bumper look but last ones had very warmed over 406 small blocks with both pipes dumping out of turn downs at the right rear wheel like some Pontiac Trans Ams. Liked this "Sleeper" look better.
Evan
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Does their have to be any crossover or interconnect or whatever it is called or can I just run 2 completly seperate runs? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | homer52
In my opinion, it comes down to what you want to do, and how fancy you want get. All the vehicle magazines (and vehicle owners)are still arguing whats the best...... pipe diameter, mufflers, headers, manifolds, steel, aluminum..........NEVER ENDS!
"Y" pipe simply gets exhaust from both sides of a V-6 or V-8 to a single pipe or single exhaust. Older cars/trucks from the factory with duel exhaust ran what is called an "H" pipe. This was, in my understanding,to equalize exhaust pressure and help exhaust pulse. This continued for many years up to the 90's(?). Now the hot item is "X" pipes! The "H" or "X" pipe is to be installed at a point of where the duel pipes are at their hottest. (This is JUST MY understanding!) Once the duel exhaust is installed, lightly spray paint exhaust system and let dry. Start motor. Where the paint burns off on both pipes, first, (closest to each) other is where the "H" or "X" pipe should be located. REPEAT.....THIS IS JUST MY UNDERSTANDING! Hopefully, someone with "MORE KNOWLEDGE" will chime in!!!
Personally, in ALL my vehicles, with duel exhaust......I"m just running two pipes with two mufflers! I Like to keep it simple!
| | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | Had the Lake pipes, (283 SBC) they were just too loud and the fumes were just to much. I removed them and have true duals through Cherry bombs right straight out the back. Sounds good and no gas mask needed.
| | | | | Joined: Mar 2010 Posts: 10 New Guy | | New Guy Joined: Mar 2010 Posts: 10 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I would not move the tank. The S-10 tank is in a good spot.
What we do is have both pipes go over to the passengers side. My mufflers are upright side by side on the passengers side, and then the drivers tailpipe crosses back over after it jumps over the axle.
I wouldn't go with lake pipes, personally.
I have an h-pipe, Since I had my exhaust done by a reputable shop (only thing I didn't do myself), they knew exactly where to put it. It doesn't hurt to put it in, but it's not necessary.
As far as mufflers, flowmaster and other companies have sound clips on their websites. I went with the 40 series delta flow flowmasters and they sound great on my 455. Quiet enough, but noisy when you're on it, and no drone in the cab.
Whatever you do, make sure the exhaust exits clear of the body and behind the rear wheels for the least noise inside the vehicle. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Some thoughts about separate duals and "X" pipes. There might be a tiny scavenge effect with the "X" configuration(might). The might be less "bark" in the sound from the "X" configuration. The muffler(or lack of one) will change every thing. Warning: Opinion! I like the pipes to exit the rear. Run the duals over the rear axle, and route one to the passenger side. Use a sheet metal heat shield to protect the MC and the bed. I like the "stock" look of these trucks. I like sneaky trucks. My 2 cents.
Steve H
