3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
Installed 12V Heater blower motor in my recirulating heater on the 54' 3600. What would be the correct size in-line fuse to use?
Ron - - Dusty53
1954 Chevy 3604
Gas Pumper
Gas Pumper
10 Amps is 5 amps more than the motor will generate on a regular basis. Since there is no 'correct' fuse for that modification, I would go with 10. You can see normal amperage readings here:
http://devestechnet.com/Home/Native12VUpgrade
in the Heater section, but the most I have seen with a PM354 12v replacement motor is a little less than 4 amps.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks Deve !
Ron - - Dusty53
1954 Chevy 3604
Fuses are not installed to protect the motor, they are there to protect the wiring.
10 Gauge wire = 30 amp fuse
12 Gauge wire = 20 amp fuse
14 Gauge wire = 15 amp fuse
16 Gauge wire = 10 amp fuse
18 Gauge wire = 5 amp fuse
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike has it!
Steve H
x2
Gas Pumper
Gas Pumper
The recommended wire size depends on what is being wired. So when they decided 16 gauge was correct for the heater as well as most systems on the vehicle, they must have done that because some day Deve would recommend a 10 amp fuse! LOL!
Deve
The Think Tank
Thanks again , everyone, Merry Christmas !
Ron - - Dusty53
1954 Chevy 3604
