3 members (TUTS 59, JW51, Jon G), 114 guests, and 4 robots.
Topics128,095
Posts1,056,480
Members48,444
Gas Pumper
Gas Pumper
Does anyone have a nice reliable picture of exactly where the original Defroster Decal went on the body of the Harrison Deluxe Heater (47-55)? Thanks! Once I know, I can update my own Heater article!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Not exactly which decal you are talking about Deve. There are no
decals on this heater which as far as I know was installed at
the time of purchase or very close to it.
http://www.pbase.com/dennygraham/harrison_h-02-47
Denny G
Denny G
Sandwich, IL
Gas Pumper
Gas Pumper
There is a decal set that you can get from the vendors that looks like it belongs just below the defroster control arm. Maybe its not for the Harrison Deluxe heater?
http://www.classicparts.com/1947-54-Defroster-Instruction-Decal/productinfo/68-555/#.VnM_qBUrKHs
Deve
The Think Tank
You do have the heaters mixed up.
The Recirculating Heater (and defroster) was supposedly the same for all Advance-Design years.
There was no defroster manual "control arm" on the "Air-Flow"/"Fresh Air" (de luxe) heaters until 1953-55. The earlier Advance-Design "Air-Flow"/"Fresh Air" heaters had a cable-controlled defroster "arm".
What type/style of heater and year of heater are you referring-to, Deve?
The decal you show has different defrost labels for different types of heaters, recirculating and "deluxe".
1947-1955st GM truck heater decals
Gas Pumper
Gas Pumper
It's just that on the same decal sheet they refer to recirculating heaters and fresh air heaters. I guess the Harrison Deluxe Heater isn't one of those two. I have a 1953 with an extended arm with knob and a 1947 one. They are fully restored with silver gray hammerite and ready to be boxed up until later. Just wanted to put everything as it should be.
Deve
The Think Tank
One/all of them might be a/the Harrison Deluxe Heater referred-to on the sheet - can you post links to photos of the heaters you are referring to?
The terms "Deluxe" "Air Flow" "Fresh Air" were sometimes used to describe the same heater in the same year. GM and its artists and "documenters" were inconsistent and "duplicitous". Heater names used in various A-D years have been listed/posted in the past.
Also, it is common that wrong year heaters were put in trucks (and non-Chevrolet truck Harrison heaters were put in trucks).
Post pictures and we can "get on the same page" and get helpful. Otherwise, meander on . . .
Gas Pumper
Gas Pumper
It's not rocket science Tim. Its the same ones Denny pictured earlier. There were two kinds for each year. Its the verbage that has me confused.
Deve
The Think Tank
Show a photo for each heater YOU are referring to.
Gas Pumper
Gas Pumper
Well, since I am not known for meandering, I got what I needed from Brad Allen. If you have a 1947-1952 Harrison Deluxe Heater, they did not come with a decal for the defroster. Great confirmation. Thanks and I think we are done here. smile
Deve
The Think Tank
Except if someone else finds this thread later looking to answer the same questions are the answers here?
Since the Deluxe heater had a cable for the defroster, there was
no need to label it on the housing. The recirculating heater
had no cable so they labeled the swing lever on the housing.
Here's a pix of one of our bolters restoration, think it might be Brads garage:
http://www.pbase.com/dennygraham/image/149025181
You can't always count on what the vendors are selling as
gospel. They are often as confused as we are, but need to
put a product on the shelf to satisfy the masses.
dg
Denny G
Sandwich, IL
Originally Posted by Deve
. . . If you have a 1947-1952 Harrison Deluxe Heater, they did not come with a decal for the defroster. . . Thanks and I think we are done here. smile
For some readers, there might still be confusion with terms/statement above: "If you have a 1947-1952 Harrison Deluxe Heater, they did not come with a decal for the defroster."
There was indeed a decal for the DEFROSTER, but, it was not on the Heater's body, because the defroster was controlled by a cable.
The 1947-52 DEFROSTER decal was on the Heater's under-dash bracket for the defroster lever's controller-cable: see middle-left decal on this sheet.
Thank, Denny, our clarifications crossed paths.
Were those decals part of the Deluxe Heater accessory package
Tim? And was there a mention of them in the packaged instructions?
I'll have to take a look in the books to see if they instruct
you to place the decal near the pull knob.
dg
Denny G
Sandwich, IL
Gas Pumper
Gas Pumper
The problem is the 1953 Harrison Deluxe Heater. It is not controlled by a cable (for Defrost). The 47-52 were controlled by the cable. (which is hard to find and on backorder for the past year).
I had a Fresh Air Heater in the shop last night helping a friend and it does have the decal, so in 1953, 54, and 55 the Harrison Deluxe had a control arm on the heater. So that is one of the questions unanswered so far.
The small decal that goes on the mounting bracket is something I haven't gotten to yet. Mostly concerned with what goes on the body.
Deve
The Think Tank
dg
Denny,
I think I do not understand your question - sorry.
"Deluxe Heater accessory package "
"in the packaged instructions"
My guess is the decals were applied when the heaters were assembled at the factory.
My assumption is the decals were on the accessory heaters when you bought a heater from GM.
That decal sheet in this thread is the non-GM-made after-market 1947-55 heater decal sheet sold by reproduction parts vendors, such as Classic Parts .
I have never seen a factory document that shows where the decals go on the Heater parts. I assume you are referring to instructions/illustrations for placement of decals, as shown in the Factory Assembly Manual for a few other decals, such as the 1954 engine valve cover decal?
I'll have a primitive webpage ready soon - with pictures of heaters.
Unfortunately, the Internet-found pictures are mostly of "restored" heaters that might not have a decal, or might have a decal in the wrong location. I'll post a link to the page soon I'll take it down if it just adds to the confusion.
Hi Guys...can you please clear up the confusion in my simple brain? Do I understand that the label on this "Fresh Air" Harrison heater body is not correct/not needed--did not originally come with one? I restored it for my '48 Chevy 1/2 ton.
http://s160.photobucket.com/user/st...363_zpslrl1n1e3.jpg.html?sort=3&o=92
If I am following the post correctly, this DEFROSTER label is correct?
http://s160.photobucket.com/user/st...376_zpskv1xy6yn.jpg.html?sort=3&o=89
Just want to have the original look! Thanks.
LUKE
Deve,
If you are interested in what goes where on the 53-55 "deluxe" heater, here are general locations:
1953-1955st Fresh-Air “deluxe” heater’s decal for inside/outside air
- middle right decal on the decal sheet
- goes on the plate for the inside/outside-air control knob/cable mounted under the dash to the left of the steering column
1953-1955st Fresh-Air “deluxe” heater’s DEFROSTER decal
- bottom decal on the decal sheet
- goes on the heater-body, under the post on the defrost flap
By the way, using the word "Harrison" to describe the heater might confuse some some readers. I do not think that GM used the word "Harrison" in sales brochures, or parts/accessory lists. All GM heaters were made GMs' Harrison division. It might be clearer to refer to a heater by the year/years and by the name "recirculating" or "deluxe"?
LUKE,
I think you are correct.
There was/is no need for a label for the defroster to be on the 47/48 "deluxe" heater box, because the defroster-flap on the box was/is controlled by a cable/knob mounted under the dash to the left of the steering column. For that type heater, the defroster label was on the bracket for the cable/knob mounted under the dash to the left of the steering column.
A "defroster" label ON any GM heater box was only needed/used when the defroster flap ON the heater box was operated/selected by a human hand moving the defroster lever/flap ON the heater box.
I hope this does not cause further confusion. Good luck.
Makes sense to me; thanks for the clarification. There is always some new minor detail to be learned by hanging around this "on-line" garage--greatly appreciated! I am going to remove the label from my heater body.
Gas Pumper
Gas Pumper
Very nice Tim! Glad it's not left to me to do everything! Now, MEANDER ON! LOL!
Deve
The Think Tank
Deve (or, anyone),
Do you have a photo of the 47-52 "deluxe" defrost cable bracket (with DEFROSTER on it)?
Gas Pumper
Gas Pumper
I might have one. I'll look tomorrow when I am at the shop if someone else doesn't chime in before. That would be a good addition for exact placement.
Deve
The Think Tank
Here is a close up I took of the defrost cable bracket from my '50 COE before restoration.
http://s1116.photobucket.com/user/1950Cabover/media/IMG_0298_zpsec5d35c7.jpg.html?sort=3&o=27
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Here is an observation with a question:
Tim has a link to the decals web page in a previous post. The parts look to be NOS parts. They include an "Air" switch, bracket with DEFROSTER label, the pull handle with cable, and the heater control valve rod and knob.
That labeled DEFROSTER bracket appears to have a "hammered" paint finish (to match the hammered heater body?). If this is correct, did the heaters that were painted silver come with a DEFROSTER bracket that was a "hammered" silver paint finish?
fonz8261,
Please post the link that you are referring to.
I have no knowledge of the different paint colors and the years they were used (and, if there were differences between Chevrolet & GMC).
I had a hard time finding photos of examples of the different heaters/controls that had used the correct labels.
Also, GM might have used AIR (outside AIR, for 53-55 outside AIR control) instead of PULL TO CIRCULATE in some 53-55 years (or, maybe, there was a difference on GMCs).
If anyone has photos of any examples, please post the links or email/PM links/photos to me.
My heater decal or metal plate looks just like Denny Graham. It is a picture on Photobucket. I don't know how to put the link on this page. Hope this helps.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
A couple of pictures of my heater rebuild.
I'm sorry I had a senior moment and started to sand on the heater and then snapped out of my funk and put it back together to record the rebuild but you can clearly see that there was only a small label under the knob to control the defroster.
http://s1281.photobucket.com/user/d...ior/Stoughton%20006_zpsmsef8hha.jpg.html
http://s1281.photobucket.com/user/d...ior/Stoughton%20017_zpsqwxzjvyu.jpg.html
http://s1281.photobucket.com/user/d.../632_zps6ce9f5b3.jpg.html?sort=3&o=6
http://i1281.photobucket.com/albums...er%20experiment/IMG_2870_zpsf7b97d56.jpg
I'll look at ordering a label or getting one made up when I'm starting to reassemble.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
doyl19503800,
That is a very interesting heater (and control knob).
I wonder when in was made?
Yes, you can see where a defroster decal was placed.
It also has an interesting heater motor speed control knob. You can see it might have had a decal above the knob? I think I have one knob like that in my collection. (but, no attachment plate)
Gas Pumper
Gas Pumper
That switch looks like it could handle the amperage better than our stock Chevy toggle switches. Wish I could see the back of it. The switch just acts as a switch on High setting, but on medium and low those resistors and heat sinks are really tasked hard. Makes good ones hard to find.
Deve
The Think Tank
Deve see links to pictures of the switch sides and back.
http://i1281.photobucket.com/albums...eater%20rebuild/IMG_2858_zpsphoukehp.jpg
http://s1281.photobucket.com/user/d...%20rebuild/IMG_2856_zpsvgn3y5i6.jpg.html
Tim
"You can see it might have had a decal above the knob? I think I have one knob like that in my collection. (but, no attachment plate)"
Hi Tim, I did clean up the plastic face plate on this switch. I'm looking for a way to rebuild the porcelain covering on the back spring which I assume is the heat sink.
Because my heater motor was seized when I bought the truck I did try the switch after I cleaned it up by hooking up direct to my 6 volt battery and had current flow in both fast and slow positions, also the small 6 volt bulb located inside the white knob does work albeit very dim.
Doyle
Gas Pumper
Gas Pumper
Thank you for that! It appears GMC had the same problem as Chevy with it getting too hot, but at least yours has a nice ceramic heat sink. Ours has no heat sink except inside the resistor which doesn't count. It looks like yours could still be in good condition.
Deve
The Think Tank
Doyle,
Your heater looks like the reciculating heater in this 1954 GMC document.
The 1954 GMC recirculating heater has a different defroster-flap handle and decal/plate than yours (I have one that I think is original - the plate was missing, I think).
