5 members (sron48, Gdads51, Wally / Montana, 49choptop, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
#1139504 12/15/2015 7:06 AM
I am putting a 350 in my 46/7, do I ( I think I do) need a coolant overflow tank. I was looking at some on ebay. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
back yard wrench turner
I put one on my 38. I'm using an original radiator that is not pressured. I installed a mason jar for the overflow tank. Occasionally I will see fluid in the jar.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I run one on both my 55's. I wouldn't leave home with it.
Brian
1955.2 3100 Truck
Have one on my '48 with 350 V8. Works as advertised.
Anytime the cooling system pressurizes enough to push the spring back on the pressure cap, a little coolant will escape. Whether it ends up on the ground or in the recovery tank is your choice. If the recovery tank isn't there, air goes back into the radiator on cool-down and the level gets lower. With the tank, the coolant gets siphoned back in with vacuum.
Sounds good. Thanks guys. Dave
1941 Chevy
Unconventional Thinker
I'm looking for a cool tank to add to my truck so the coolant doesn't go to the ground.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Here is a Google images for Homemade overflow tanks
Wayne
1989 Silverado
@Wayne67vert
NICE!!! I have some bottles at home that I can convert into a tank.
Shane
Shane's Toys...
I'd use a Jack Daniel's bottle!
1952 Chevrolet 3800 pickup
---All pictures---
Gas Pumper
Gas Pumper
Grigg that's just insanely cool. That puts anything I can make in my shop to total shame. Very nice work!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
WOW has this got me to thinking. Does the overflow container have to hold pressure, if so how much? I am now on the search for something unique. Dave
1941 Chevy
No it doesn't. Just run the hose from the radiator all the way to the bottom of the container so the antifreeze gets sucked back when the fluid cools.
Wayne
1989 Silverado
It was actually a pretty simple soldering job, the machine work was just bandsaw, belt sander, and a hole saw. Did use a lathe to make/modify the drain fitting to look about like the original, not a necessary step for function though.
I wanted brass because the original rusted out, wanted this one to last. Was going to roll a can and make a seam until I found that cartridge she'll in my brass stock and it happened to be the right diameter plus and minus a tiny bit of taper from 5".
The one I made actually does hold pressure, it is open to the full radiator pressure connected by a 3/8" hose and the tank has the pressure relief cap. That's the way it works on a GMC 860 and some other old trucks, I suppose like new stuff too.
If the pressure relief cap is on the radiator then you don't need the surge tank to hold pressure.
---All pictures---
Here's what I threw together last month
Overflow
The GMC 630 I drove to KC had the pressure relief valve and overflow tube built into the top radiator tank, and a screw-on gasketed fill cap. Of course, it also had a 503 cubic inch inline six!
