4 members (Jim K, tclederman, Lightholder's Dad, Biermann), 113 guests, and 0 robots.
Topics128,163
Posts1,056,918
Members48,458
reason im asking i bought one
title says 1950... seems to be a 51 to me tho
A couple of differences come to mind. First, 1950 was the last year of one-piece side window glass (no vent windows). second, I believe 1950 had a vent door on the side of the cowl. 1951 was the only year the AD's came with BOTH turn-down door handles AND vent windows. I'm pretty sure 1950 was the first year for modern type tubular shock absorbers and I believe 1951 was the first year for Bendix type drum brakes (as opposed to the earlier "huck" style). Hope this helps and also hope someone more "in the know" will correct me if I'm wrong.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
Anonymous
Unregistered
Anonymous
Unregistered
You are right on track WABAD. Redspeed what does the VIN plate say ??
thanks alot
i was leaning toward a 51
but was quite sure
title says 50...but not the original
got the bendix drum brakes , vented glass
tubular shocks...
y'all are great
kinda hard to restore something where you buy the
wrong year parts
51 max speed shows 80mph,bed change from 9 to eight mid yr.seat adjustment is located under cushion and secured to seat frame---Fred
Redryder pix
My Hotrod
