| | | Forums66 Topics128,162 Posts1,056,932 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | reason im asking i bought one title says 1950... seems to be a 51 to me tho | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | A couple of differences come to mind. First, 1950 was the last year of one-piece side window glass (no vent windows). second, I believe 1950 had a vent door on the side of the cowl. 1951 was the only year the AD's came with BOTH turn-down door handles AND vent windows. I'm pretty sure 1950 was the first year for modern type tubular shock absorbers and I believe 1951 was the first year for Bendix type drum brakes (as opposed to the earlier "huck" style). Hope this helps and also hope someone more "in the know" will correct me if I'm wrong. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | You are right on track WABAD. Redspeed what does the VIN plate say ?? | | | | | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | thanks alot i was leaning toward a 51 but was quite sure title says 50...but not the original got the bendix drum brakes , vented glass tubular shocks... y'all are great kinda hard to restore something where you buy the wrong year parts | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | 51 max speed shows 80mph,bed change from 9 to eight mid yr.seat adjustment is located under cushion and secured to seat frame---Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
