5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#113947 10/06/2003 9:41 PM
Fox
Offline
When i tore my truck down, the cab mounts were rusted out bad on the frame. frown Stupidly, I took them off without measuring and now i can't find them. Nearing the point where i am going have the cab back on, so i need to know the exact dimensions of the layout, so I can make some new ones. I've tried getting measurements from the cab, but it is awkward and probably not as accurate. The truck is a 50 1/2ton. Hopefully someone out there can cure my stupid mistake.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
#113948 10/07/2003 2:32 AM
If I understand correctly, you are saying you lost the rear cab mounts? And now want to make new ones? That sounds like a LOT of work. Why not call a vendor and get some used ones? Up in Canada, there is Iron Chief, in Alberta I believe.
#113949 10/07/2003 6:07 AM
I'm pretty post dumb, but I have a factory assymbly manual that has the measurements. If I could post it I would so, I hope that gives you a good place to start. Wish you luck and fun. O smile
