| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | When i tore my truck down, the cab mounts were rusted out bad on the frame.  Stupidly, I took them off without measuring and now i can't find them. Nearing the point where i am going have the cab back on, so i need to know the exact dimensions of the layout, so I can make some new ones. I've tried getting measurements from the cab, but it is awkward and probably not as accurate. The truck is a 50 1/2ton. Hopefully someone out there can cure my stupid mistake. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | If I understand correctly, you are saying you lost the rear cab mounts? And now want to make new ones? That sounds like a LOT of work. Why not call a vendor and get some used ones? Up in Canada, there is Iron Chief, in Alberta I believe. | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | I'm pretty post dumb, but I have a factory assymbly manual that has the measurements. If I could post it I would so, I hope that gives you a good place to start. Wish you luck and fun. O  | | |
