4 members (frogfarmer, Peggy M, baldeagle, Gray_Ghost), 66 guests, and 11 robots.
Topics128,020
Posts1,055,345
Members48,419
#1139260 12/14/2015 1:38 AM
Many wheels were pinstriped back in the day. I know the striping varied from year to year but I don't know what theme was used for a specific year. I do know from factory photos that the '54 GMC had none.
All you folks with original wheels, would you post the stripe theme and widths and year of truck.
I've also noticed cab pinstriping variations. If your truck has any traces left please post the details.
Cletis #1139265 12/14/2015 2:04 AM
I don't have any pictures of the beltline pinstripes, but I have seen several originals (some 54 Chevrolets, no GMC's), and they varied in width and placement. Some were approximately 1/8", and others were 3/16". Some were lined up with the center line of the wiper bezel, others were lower. The one trait which they all shared was crudeness of application. They had roundish stops and starts at the intersections of cowl, doors, and lock pillars.
Carl
52Carl #1139266 12/14/2015 2:10 AM
The pin striping of the day was hand done. The width depended on the painter and choice of brush. The location depended on the size of his hand and the feature he picked as a guide.
Not to mention what kind of a day he was having.
Cletis #1139272 12/14/2015 2:43 AM
tclederman #1139406 12/14/2015 9:52 PM
Here are a coupla pictures from a '53.
On the cab
More on the cab
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Jim Sears #1139418 12/14/2015 11:09 PM
and don't forget lubrication and how much smoke got in his eye. There was always smoke in your eye...
Give me ambiguity
or give me something else
CASO #1139423 12/14/2015 11:25 PM
This is an original paint, 2700 mile, un-restored '49 GMC. Wish it were mine! pin stripe There are several photos of this truck I took, so scroll through the album. You may have to "go to album" as for some reason it is not showing the photos in the order I took them and are arranged to show the pin stripes. GMC unlike Chevy did not stripe the wheels.
Mike
Cletis #1139452 12/15/2015 1:35 AM
ODSS President
ODSS President
~ Cosmo
1949 Chevy Half Ton
Cletis #1139473 12/15/2015 3:07 AM
What year are your wheels, Cosmo?
Cletis #1139484 12/15/2015 3:52 AM
ODSS President
ODSS President
I don't know. I'll be able to make a call to the man who gave me the wheels in the next few days.
~ Cosmo
1949 Chevy Half Ton
Cletis #1139511 12/15/2015 11:59 AM
Cosmo, in this picture, it appears the center was cut out of the drum, how did you do that?
http://s104.photobucket.com/user/49Cosmo/media/002.jpg.html
tks
Denny G
Denny G
Sandwich, IL
Cletis #1139610 12/16/2015 12:40 AM
I finally remembered to check the trucks in my yard before dark today.
'53 Chevy yard dog, 3/16" stripe about 3/16" above cab joint.
'50 Chevy half ton, 5/32" stripe about same position.
'51 GMC 2-ton, 5/32" stripe about same position.
'47 Chevy 2-ton, 3/16" stripe about same position.
Greg Hill sent me pics of his '54 Chevy half ton, 1/4" stripe about same position.
'54 GMC did not have a stripe.
Organ builder's '53 Chevy and the '49 GMC Huck linked to seem to be consistent with these.
I'm thinking the position was set by the book for all AD/ND years that had the stripe. The width varied with the striper.
Cletis #1139620 12/16/2015 2:07 AM
Used to pin stripe buggy and carriage wheels with a striping wheel which I still have.
May give it a try.
Cletis #1139684 12/16/2015 12:00 PM
Do you mean, like this Stan?
http://www.pbase.com/dennygraham/image/154490555
How'd you get that to work? I never could get it to
lay down a very good line.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Cletis #1139687 12/16/2015 12:56 PM
ODSS President
ODSS President
I was at Hershey or Carlisle one year and a guy had a jig for a Bugler striper to do wheels (off the car, horizontally). Very trick set-up!
~ Cosmo
1949 Chevy Half Ton
Cletis #1139690 12/16/2015 1:17 PM
I gave my painter a knuckle/spindle with a drum/bearings on it. He mounted and spun each wheel - touching the applicator to the spinning wheel. He cursed at me because my tires were already mounted (the air-filler stem got it his way).
The 1/8" stripe on my 1954 Suburban wheels (to match the original 1/8" stripe on the cab "belt").
Cletis #1139718 12/16/2015 4:53 PM
Denny. Mine is a Beugler and works very well. You have to remember to pull it as the wheel pulls paint from the bottom and lays it down. Perhaps its the machining of the parts. The Beugler is a pricy beast and very well put together. I had no trouble with it. The trouble I had was following a line. My eye wants to look ahead rather than behind. Doing a four foot diam. wheel and spokes was easy.
Cosmo #1139722 12/16/2015 5:14 PM
The wheels on my 41 are similar to the ones in Cosmos photo bucket, only the outer perimeter stripe is not as wide. I am not positive if these are the original wheels for my truck however the rest of the truck has been totally original accept the home made rear bumper and added on rear fender braces. Scott
