2 members (Guitplayer, Achipmunk), 61 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1139389 12/14/2015 8:09 PM
MFW
Offline
I have a 1954 3100 stock 235 without a filter setup. I was wanting to add a filteration setup. I was thinking about tracking down an original setup up or buying one from Napa. Which direction do you guys recommend.
Matt
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
Bypass oil filter or full flow?
If bypass I'd find an old/original one.
If full flow I'd hide a modern spin on filter under the generator or behind an alternator.
http://www.stovebolt.com/techtips/full_pressure.htm
http://devestechnet.com/Images/Projects/FullFlowOil/CosmoGrigglg.jpg
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
MFW #1139407 12/14/2015 10:11 PM
MFW
Offline
I just want something that's going to work well. Is the full flow the most effective?
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
MFW #1139409 12/14/2015 10:21 PM
Matt,
If you choose to go the full-flow route, you would have to do some modification to the block.
The by-pass filter system works fine.
Jim Carter sells a by-pass filter "head" that uses a spin-on filter.
If you want an original-style by-pass filter, post a want-ad in the Swap Meet (or, ask Jim Carter if they have a used one - you might as well ask if the have a 1954-style used one).
http://www.stovebolt.com/techtips/engines/oil%20filters/index.html
MFW #1139412 12/14/2015 10:36 PM
Leo Online: Content
Moderator
Moderator
I'm happy with my bypass filter. They're easy to install and look good up there.
MFW #1139415 12/14/2015 11:00 PM
MFW
Offline
Sounds like the by pass is the easiest way to go. Is there much to modify to get it installed?
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
MFW #1139420 12/14/2015 11:14 PM
Here is the instructions for the install: http://chevy.oldcarmanualproject.com/miscellaneous/oilcanister.htm
Should have every thing you need. The filter was a Dealer installed Accessory.
Steve H
MFW #1139427 12/14/2015 11:36 PM
The filter was actually a Regular Production Option installed at the factory.
HOWEVER, it could be purchased as a GM part by the dealer or the owner. Other brands of by-pass oil filters were also readily available (Fram, Western Auto, Sears, J C Whitney, etc) - these could be bought and installed by the dealer or owner or auto repair shop.
If you buy a used filter and need lines, buy the longest lines available in set from many vendors: Jim Carter, Classic Parts (Trucks), Chevs of the 40s, etc. Some vendors sell lines that are not quite long enough for some of the by-pass filters.
MFW #1139432 12/15/2015 12:02 AM
MFW
Offline
Thanks guys for the information. I am going to try and locate one. Hopefully they aren't too pricey.
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
MFW #1139439 12/15/2015 12:32 AM
Its easy to do a spin on filter and stay bypass. Fram PB50 has the small bypass orifice.
Matt,
I have a correct 1953-1954 oil filter canister and block fittings for a 235. It even has the original oil lines (for reference to make new ones).
1959 3100 Apache Fleetside
