1 members (Phak1),
48
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 14 New Guy | | New Guy Joined: Apr 2015 Posts: 14 | I inherited a project that was already disassembled. That in itself makes it hard to see what's what. My first of MANY questions is I am putting a first gen 350 sbc in this 63 GMC shorty fleet with a TH350. The truck came with it lowered a bit , 4wdb, power steering, and sway bars. Other things as well but let me start with those. I mounted the engine on new mounts using the front two of the three holes. I was planning on not using a Wp mounted fan so I thought this was ok. What I really need from you guys is to find out what headers I should use. I thought my old long tube headers from my 69 ss Camaro would work. (this motor came out of that car) but no room. So what should I buy? And how do I post pics?? DAN | | | | | Joined: Apr 2015 Posts: 14 New Guy | | New Guy Joined: Apr 2015 Posts: 14 | | | | | | Joined: Apr 2015 Posts: 14 New Guy | | New Guy Joined: Apr 2015 Posts: 14 | | | | | | Joined: Apr 2015 Posts: 14 New Guy | | New Guy Joined: Apr 2015 Posts: 14 | Well at least you can click on the photobucket site and see the eng. I think... | | | | | Joined: Apr 2015 Posts: 14 New Guy | | New Guy Joined: Apr 2015 Posts: 14 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put stock ram horn manifolds on it. Unless you are going racing you will be better off. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 | Put stock ram horn manifolds on it. Unless you are going racing you will be better off. ^^^This^^^ Ramhorns are almost just as good as headers from dyno test results I've seen. The torque and horsepower numbers were so close it was amazing. For simplicity and not needing to worry about re-torquing the headers, and making spark plug changes easier, ramhorns are better. dyno results - headers vs ramhorn manifolds
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | It would be hard to run fast enough to give me a set of headers if you wanted me to run them on a street engine. Ram's horns, or even the later model rear-dump cast iron exhaust manifolds will be a lot easier to plumb, they won't burn out plug wires from exhaust gas leaks, and the underhood temperature will be about 100 degrees cooler! Jerry
| | | | | | Neverdone Unregistered | | Neverdone Unregistered | Doctor , In my opinion there is but one choice ...Sandersons .sweet.. tight .. and quality Dan | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | And how do I post pics?? DAN check out the IT short bus for pic posting information... the short version, you will need your own webspace or a photo hosting site of some kind to link to. IT short bus flickr, imgur, photobucket and whatever the others are... -W | | |
