7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami), 60 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#1139043 12/12/2015 7:45 PM
The 235 in my 51 has been running great until today. All the sudden when warmed up there is an intermittant squeal from the FRONT of the engine. I soaped the belt but no change. I listened with a steel rod at the generator and water pump. Not there. They are both new. Best I can tell it is coming from the lower part of the engine under the timing gear cover?? Any ideas?
Thanks, Howard
cassie #1139048 12/12/2015 8:15 PM
More info. I turned the engine off while I did the first post for about 10 minutes. Started it up, drove it, let it idle--no squeal.
Any thoughts?
Thanks, Howard
cassie #1139050 12/12/2015 8:25 PM
H Online: Content
Loose or glazed fan belt. As soon as the battery recharges a little from the load of running the starter, the belt quits slipping. You're hearing the belt squeal as it slips on the crankshaft pulley as it tries to drive the generator or alternator under the load of recharging the battery. Tighten or replace the belt.
cassie #1139065 12/12/2015 10:44 PM
Very possible.It is a new belt so it could have stretched. I tightened it up a little. Usually the soap trick works to find the cause but maybe not always. Hope this takes care of it.
Thanks, Howard
cassie #1139120 12/13/2015 6:10 AM
Are you sure the belt is wide enough? If it is to narrow, it will ride on the bottom of the pulleys and slip. V-belts were made to run on the V part.
cassie #1139157 12/13/2015 2:52 PM
It was incorrect when I got the truck.I had to replace the harmonic balancer so all grooves and belt matched.
Thanks for the response.
Howard
