1 members (Wooley),
105
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 24 Member | | Member Joined: Dec 2001 Posts: 24 | In the tech papers of zerorust it says some paints (top coat)may not work with it. Is this something i need to worry about when i prime it and have it painted? Do i have to be specific in what paint i tell the painters to use? Also where can you buy zero-rust
[ 12-06-2001: Message edited by: 52GMC ] | | | | | Joined: Nov 2000 Posts: 17 Member | | Member Joined: Nov 2000 Posts: 17 | The reason for our cautionary statement is that with more restrictive EPA rules, more paint manufacturers are using more acetone as their VOC and because of its aggressive nature, it can cause lifting problems. This can be overcome by simply shooting a "tack coat" of your topcoat material to basically lay a barrier down that will then permit you to shoot a flood coat without problems. Test panels are always one way to help alleviate any potential incompatibility problems, but the above procedure is tried and true remedy of long standing. You may have some distributors in your area, however you can order online 365/24/7. HTH WK Irish | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If I knew it was that close, I will have to drive there and get it! (2&1/2 hours if I push it a little)
