2 members (walter74, klhansen), 117 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#113886 05/22/2004 9:01 PM
I know I can get the bed mounting bolts. But, where can I get the bushings?? All of the bed mount bolt kits I've looked up, don't come with the bushings. Anyone have a line on bushings? Or, do I have to make my own?
Jim Sgrig
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#113887 05/24/2004 4:05 AM
is this yer 66 panel? the task force just uses rubber shims to align everything and prevent squeaks - get some 1/8-1/4" neoprene to match the back body height to the front cab mounts [which prolly have doughnuts or rubber washers] - if it's a pickup, pretty much the same for the bed, just rubber shims
#113888 05/24/2004 11:22 PM
Squeeze,
Yes, It's my '66 panel. I can just use the pickup bed bolt kit, can't I?? I can cut rubber shims from old tires out of the junk pile at work. I did this with my '49 panel. That worked out ok.
Jim Sgrig
