1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | I know I can get the bed mounting bolts. But, where can I get the bushings?? All of the bed mount bolt kits I've looked up, don't come with the bushings. Anyone have a line on bushings? Or, do I have to make my own? Thanks,
Jim Sgrig | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | is this yer 66 panel? the task force just uses rubber shims to align everything and prevent squeaks - get some 1/8-1/4" neoprene to match the back body height to the front cab mounts [which prolly have doughnuts or rubber washers] - if it's a pickup, pretty much the same for the bed, just rubber shims
Bill | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Squeeze, Yes, It's my '66 panel. I can just use the pickup bed bolt kit, can't I?? I can cut rubber shims from old tires out of the junk pile at work. I did this with my '49 panel. That worked out ok. Thanks,
Jim Sgrig | | |
