9 members (Cosmo, VicZ, Patina 54, Wally / Montana, Mike Burns, Ponchogl, HandyAndy, 2 invisible),
191
0
Mod | | | Forums66 Topics128,087 Posts1,055,977 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those are post-60 wheels, the 58 caps won't fit, although later truck caps look OKsee here for 58 cap dimensionsBill | | | | | Joined: Aug 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 48 | Thanks for the help red58! Now when you say they won't fit is that because they physically won't fit in the wheels center opening or is it because there are no clips in the center to hold the cap in place? I found the clips for sale online so I was thinking I could add them to my wheels but if the cap is too big to fit in the hole then that's not going to work. I was thinking my wheels were post 60 based on looks but wasn't sure. If I can't get the original style to fit what I have I was thinking these might look good. http://s824.photobucket.com/user/keenebolter/media/58%20Apache/63%20hub_zpssofd4e1v.jpg.htmlI believe these are correct for post 60 rims? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those do strike me as 61-66, I think they'd fit the lumpy rims .... the dimensions of the original caps just don't match the later wheel centers, I doubt you could position the clips to hold the caps, and the lumps would be outside the rim of the caps
Bill | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | There are a couple of yards here in East TN that have trucks with wheels. Here are their numbers.
Millers (865) 767-3070 Dentons (865) 933-7370
1959 3100 Apache Fleetside
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | You're going to need the three clip rims. They are 56 to 59 only. These will have a 5" bead width. Available in 15" and 16".
Beware the 6 clip rim, they are 4.5" bead width. 55 and older ran those.
| | | | | Joined: Aug 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 48 | Thanks for the help guys. I was hoping to save some money and make what I have work but looks like I'll have to find the correct rims after all. For now these work and maybe I can find some caps that will look decent till I can get the real thing. Thanks again! | | |
