0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 31 Member | | Member Joined: Nov 2001 Posts: 31 | Any advice on restoring plated parts like hood hinges, striker plates, bolts, etc? Thanks! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've been using Cold Galvanize spray paint [very thick zinc coating] and am happy w/ the life span considering the cost of getting the proper plating redone.
Bill | | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | Great topic! I'd like to hear more. I have a box of parts I'm going to have plated but haven't looked into the cost yet. On an AD, should this stuff be cadmium plated? Is that what it was originally? Or is is zinc plated? Anybody ever try that zinc plating kit that Eastwood sells? | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I've been using the copy cad/zinc kit from Caswell plating and have been very happy with it. Can't do anything big but has been fine for nuts and bolts,clips,small brackets,springs,etc. The work is a little tedious since the parts have to be absolutely clean and free of any rust. My usual procedure is to wire brush the part first followed by sandblasting,a soak in muriatic acid to remove any remaining rust, another wire brushing and then degreasing. I know it sounds like a lot,but if any minute trace of rust is left it will get worse quickly after plating. Probably would be easier to ship it all to a plater, but I've got so many of the original fasteners I'm reusing that either I'd be taking a handful every week or I'd have a huge pile and forget where they all go.Have also been using the black oxide kit from Eastwood using the same procedure and have had good results with it also. www.caswellplating.com | | |
