| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Intake runner I separated my manifolds today, cleaned them up and promptly found this! Any way to repair this hole? | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | You probably can, but intake manifolds are easy to find, just replace it. There is a casting number on it, if you want to find the exact replacement.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, you have your own natural EGR setup! Your truck was ahead of its time. | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Yep a bit ahead of its time. The welding instructor at the school I teach at tried to repair it with no luck at all...Now the hole is Much bigger!
Shopping around for an intake/exhaust manifold as I type!
Jackie | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Jackie,
PM sent.
Kind regards,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | |
