| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | My 41 has a cut out (that's been covered) for an outside door on the passenger side. I would like to put one on the drivers side. Looks like I'm missing a "rod" that would go from the keyed lock cylinder to the door handle lock.
Can you let me know what it looks like and will the lock cylinder and rod work on the drivers door?
Thank you.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 41 should have the lock in the handle. I have my 46/7 in pieces right now and if you want pictures of anything let me know and I will get then. Seems to me the door is slightly different where the lock sits, I will look at mine today as I have a 41 and a 46 to look at. Dave
just thought of another thing. You may need to also cut a slot in the area below the striker for the locking clip for the lock. Your passenger door may also not be from a 41.
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Thanks Homer. You're right, my doors could be from anywhere. I don't have a lock in the driver's door handle.
I saw them at JC's and I would get a pair of them if I knew they would work in the doors, and I could get or make a rod for them. This is not a stock 41 I'm going for here; just want to make sure I can lock it.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I looked at my 46 door and the area around the lock is different than the other door. Look at the difference in your doors in that area. Dave
The lock should have been in the passenger door handle.
