0 members (), 89 guests, and 0 robots.
Topics128,049
Posts1,055,637
#1138458 12/08/2015 5:57 PM
V
VEW
Offline
V Offline
My 41 has a cut out (that's been covered) for an outside door on the passenger side. I would like to put one on the drivers side. Looks like I'm missing a "rod" that would go from the keyed lock cylinder to the door handle lock.
Can you let me know what it looks like and will the lock cylinder and rod work on the drivers door?
Thank you.
~ Victor
1957 3100 - moved on
41 should have the lock in the handle. I have my 46/7 in pieces right now and if you want pictures of anything let me know and I will get then. Seems to me the door is slightly different where the lock sits, I will look at mine today as I have a 41 and a 46 to look at. Dave
just thought of another thing. You may need to also cut a slot in the area below the striker for the locking clip for the lock. Your passenger door may also not be from a 41.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
V
VEW
Offline
V Offline
Thanks Homer. You're right, my doors could be from anywhere. I don't have a lock in the driver's door handle.
I saw them at JC's and I would get a pair of them if I knew they would work in the doors, and I could get or make a rod for them. This is not a stock 41 I'm going for here; just want to make sure I can lock it.
~ Victor
I looked at my 46 door and the area around the lock is different than the other door. Look at the difference in your doors in that area. Dave
The lock should have been in the passenger door handle.
1941 Chevy
