5 members (UtahYork, BC59, KEVINSKI, dt235sd, 1 invisible), 94 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
1991 GMC Sonoma rear brake line failure repair.
This line failed in the driveway. Pictures
All I did was push hard on the brake pedal.
At first I could not get the the line to seal.
I was doing a single flare.
Didn't know you have use a double flare.
It ether failed because of rust on the outside or from internal toxic old brake fluid.
It failed were it bends away from frame.
That hose on the frame is the rear axle vent tube.
It could of happen driving down the road Whoa!
Anyone know how to crack open rusted wheel brake cylinder bleeder screws?
Heat it up first!
I would use a six sided socket.
1951 1 Ton Completed
Penetrating oil, 6 point socket/wrench, some heat, perhaps a small impact wrench to tickle it out without wringing it off.
Otherwise don't waste too much time and effort on it, a new wheel cylinder is under $10.
•1952 Chevrolet 3800 pickup
---All pictures---
