4 members (Don88, Hotrod Lincoln, Tiny, 1955 1 Series), 143 guests, and 2 robots.
Topics128,162
Posts1,056,935
Members48,458
Horn Pic
Does anyone have any background info on this horn? Specially, manufacture and if you have seen it as an accessory in any of the GM/ Chevrolet car/truck parts catalogs. It is not listed in my GMC master parts catalog from 1954 however the accessory section is just limited to trucks. The rear housing is very similar to Delco’s stock horn but there are no markings to be found on the horn. Thank you.
They use to have town and country horns. May be one or the other.
I don't know anything about it, but I have a parts truck with one like that. It has a really or two on it and I have been meaning to see if it still works.
I hooked mine up to a 6 volt battery charger to test and it was not enough power. Tested fine when hooked up to my 6 volt battery. If you have the time, it would be nice to see how your horn is mounted in your truck. Thank you,
mjl
