| | | Forums66 Topics128,284 Posts1,058,528 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | Horn Pic Does anyone have any background info on this horn? Specially, manufacture and if you have seen it as an accessory in any of the GM/ Chevrolet car/truck parts catalogs. It is not listed in my GMC master parts catalog from 1954 however the accessory section is just limited to trucks. The rear housing is very similar to Delco’s stock horn but there are no markings to be found on the horn. Thank you. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | They use to have town and country horns. May be one or the other.
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I don't know anything about it, but I have a parts truck with one like that. It has a really or two on it and I have been meaning to see if it still works. | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | I hooked mine up to a 6 volt battery charger to test and it was not enough power. Tested fine when hooked up to my 6 volt battery. If you have the time, it would be nice to see how your horn is mounted in your truck. Thank you, mjl | | |
