4 members (DadsFirstPickup, Otto Skorzeny, 1955 1 Series, 1 invisible), 46 guests, and 4 robots.
Topics128,089
Posts1,056,366
Members48,442
#1138167 12/06/2015 11:32 PM
I need a fuel tank for my 1947 2-Ton, Options? No mounts or tank every thing got robbed I guess for another truck.
1947.2 Chevy 2-Ton 161". Motor- 1962 235cid
If you are trying for a faithful restoration, post on the parts wanted and and do web searches and You'll find one.
If not, a tank shop can make you one that will look a lot better than the original (seriously ugly}.
I did a tank on one side and a matching storage box in the other.
I have a 47 1.5 ton. I dont know if you have Isuzu trucks over there. I found a mid size isuzu truck tank that had the same mounting centres (400mm I recall), baffles in the tank at the right place for the mounts, and dimensionally it was a couple of inches shorter end to end but only about 10mm out height and width. i could have used the Isuzu mounts but the Chev ones were perfect with about ten minutes smithing. So it may pay to have a look around a wrecker.
I unwound the nichrome wire off the chev fuel gauge sender, rewound the Isuzu one with it- that was a mission but it worked.
The filler cap was in a different place, but fine, and its locking cap sealed nicely. I ran a new tube for the vent up to the underside of the deck and down behind, all good.
'47 Canadian RHD 1.5 ton truck
Don't you love it when a plan comes together! Nice job hunting one down and making it fit!! How bout a pic of your 47?
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
Who's Plan? I am still for a fuel tank and or ideas on how to mount one. Can some please post a picture of an orginal setup?
•1952 Chevrolet 3800 pickup
---All pictures---
Thank You Mr Grigg. Is the Big Bolt tank the same as the 1-ton fuel tank?
1947 fuel tanks were most like those in 1948?
Probably 18 gallons (unless you have a school bus)?
If mounted outside the frame I bet they are the same, and likely same if mounted inside the frame but I am not sure.
---All pictures---
Jim Carter has this set-up. Looks complete I'm not sure how the gas cap would attach. Clamp on or or maybe have it tigged inplace.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEG159&i=10525|||||
Thank you for the Photo's
