3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#113812 11/01/2004 5:04 AM
Hi,
Is there some solution that will dissolve old bondo on fenders and such? I'm sure there must be a better way than beating the crap outta the panel and watching it fly! grin
I'm going to try to salvage a front fender on my '53 this winter that has quite a few dents and a ton of bondo.
There are no "redi-strips" or other metal refinishers near here (Billings) so I'll have to do it the old fashioned way; lots of elbow grease and brute force! grin If there is anything that will eat through that stuff, I'd like to know!
Steve
#113813 11/01/2004 6:33 AM
Junior Member
Junior Member
Try warming it with a propane torch and scraping it out with a putty knife.
You'll get a feel for how much heat it takes to soften it up and then easily scrape it out. An oxy-acetylene outfit will go faster, because it'll make more heat, but you don't want to over do it, either.
Tim
Stellar Antique Auto Restorations
Tim
#113814 11/01/2004 7:31 PM
I
I Offline
I asked a similar question a while ago.
Aircraft stripper works but takes a while and will need a few applications. I used the stripped to get the majority and then used a sander to get the remnant bits.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#113815 11/10/2004 3:59 AM
Junior Member
Junior Member
if you cannot use an open flame in your workshop you can always use a paint stripping heat gun , the bondo will soften up like putty and you should be able to take it off with a good stiff scraper or 1" chisle
